sddspfit for high orders
ksenia
Post by ksenia » 14 Apr 2015, 04:41
Function sddspfit seems to return incorrect result of fitting in some cases. Works well for polynomial orders 0,1,2 - but gives constant offset when I add orders of 3 and higher.
The example of data file and script attached (SL6 and SL7 were used)
Thank you!
Ksenia, BINP
pfit_report.tar.gz
(461 Bytes) Downloaded 686 times
Re: sddspfit for high orders
Post by michael_borland » 14 Apr 2015, 08:22
Ksenia,
The problem is that the independent quantity (H6) has a large average value compared to its range. This causes numerical precision problems. You can fix this by adding the -autoOffset option, but should realize that the meaning of the fit coefficients is then changed.
