Kicker vs Quad Kicks
tennant
Post by tennant » 10 Apr 2015, 13:14
I wanted to simulate transverse kicks along a beamline. I did it two different ways: (1) using a kicker element placed between two halves of a quadrupole and (2) using the h/vkick parameter of the quadrupole itself. Using the same transverse kick for each, I find different results (i.e. sddsplot -col=s,Cx -graph=lines,vary -split=page *.cen). I've attached example files.
I greatly appreciate any help resolving the discrepancy, or correcting my (mis)understanding.
chris
test.lte
(765 Bytes) Downloaded 541 times
test.ele
(1.5 KiB) Downloaded 557 times
both.sdds
(429 Bytes) Downloaded 521 times
Re: Kicker vs Quad Kicks
Post by michael_borland » 14 Apr 2015, 08:16
Chris,
I have a little trouble understanding your example, but I did a simple test and things work as expected. One point to realize (which is not stated in the manual), is that the kicks are applied at the entrance and exit of the magnet. I.e., the sequence is
HKICK/2, VKICK/2, QUAD, HKICK/2, VKICK/2
Hence, you might see some slight differences from
QUAD/2, HKICK, VKICK, QUAD/2
Hope this helps.
tennant
Post by tennant » 14 Apr 2015, 08:24
Thank you for the clarification. I was under the impression the kick happened once at the center of the magnet. This makes it clear.
Thank you Michael!
