Hi there!
I'm having troubles using the #INCLUDE feature in an elegant lattice under Linux. The program seems to always convert the include path to uppercase letters. Since Linux paths are case sensitive, I get a file not found error like this:
Unable to find file /HOME/FSY/DONDREKA/LNX/OPTICS/ELEGANT/SIS100/SUITE/SLOWEXTRACTION/OUTPUT_SLOW/WARM/CLATTICE_SLOW_LINEAR_WARM.LTE
If I put the file into the directory from which I run elegant and convert its name to all uppercase, it works. But of course I would like to avoid this kind of hack.
Regards, David
Problem with #INCLUDE under Linux
Re: Problem with #INCLUDE under Linux
David,
Just use quotation marks around the filename, e.g.,
#include: "latticeData.lte"
thanks for the quickly. I should've tried that myself, though.
Regards, David
Regards, David
