error message in smoothDist6
I am trying to use "smoothDist6s" . But an error message comes out like:
$ smoothDist6s -input a1_a4j8_200k.sdds -output a1_s.sdds -factor 2 -rippleAmplitude 5
-rippleWavelength 1
Error1: Error for C:\Program Files (x86)\APS\SDDS ToolKit\sddspfit.exe:
Unable to open file /tmp/tmp5588-Staff.fit for writing (SDDS_InitializeOutput)
I am using cygwin in Windows PC. Please help me to solve this.
Heung-Sik
-rippleWavelength 1
Heung-Sik
Re: error message in smoothDist6
Heung-Sik,
My guess is that you need to create the /tmp directory within cygwin or give yourself write permission.
The /tmp directory exists within cygwin.
Heung-Sik
Heung-Sik
Heung-Sik,
Do you have write permission? Try
echo test > /tmp/myTestFile.txt
It works well.
Heung-Sik
It works well.
Heung-Sik
The problem is that /tmp is a cygwin concept and sddspfit is not a cygwin program so it doesn't know how to access it. I believe I have a solution. Try editing smoothDist6s and replacing:
set tmpRoot /tmp/tmp[pid]-$env(USER)
with
if {$tcl_platform(platform) == "windows"} {
set tmpPrefix [join [split $env(temp) \\] /]
} else {
set tmpPrefix /tmp
set tmpRoot ${tmpPrefix}/tmp[pid]-$env(USER)
Let me know if this fixes it for you.
with
} else {
set tmpPrefix /tmp
Dear Soliday,
Thank you for your help.
I tried to do as you recommend, but I failed to have the same result.
Unable to open file /tmp/tmp8948-Staff.fit for writing (SDDS_InitializeOutput)
Please check the file I edit attached.
Happy New Year!
Regards,
Heung-Sik
Happy New Year!
Regards,
Heung-Sik
Not sure why it isn't working but you can try to force it to use c:/temp by changing:
to
set tmpRoot c:/temp/tmp[pid]-$env(USER)
You will have to make the c:/temp directory if it doesn't already exist.
This will remove /tmp completely from the script
to
Dear Soliday,
It does work well.
Many thanks.
Heung-Sik
It does work well.
Many thanks.
Heung-Sik
