I am trying to simulate some CSR studies within a 2ns delay chicane. The set up is simple enough but I keep running into the "IGSEGVProgram" error. Checking the *.cen file I noticed I was losing a ton of particles through out the chicane. Any suggestions?
I have been adjusting the bin size but to no success. Maybe I need to reconfigure the hgap (set it to zero so no edge effects). Any help would be greatly appreciated.
Thanks in advance...
CSRCSBEND SIGSEGVProgram Problem
- delay_chicane.lte
- (1.2 KiB) Downloaded 531 times
- delay_chicane.ele
- (1.31 KiB) Downloaded 535 times
Re: CSRCSBEND SIGSEGVProgram Problem
The problem seems to be that the charge specified in your .lte file is corrupted and translates into something very large.
When I change this to
the simulation runs without error.
C: CHARGE,TOTAL=3.125.125.2E-09
C: CHARGE,TOTAL=1E-09
Haha! And I thought I double checked the charge...Thanks Michael!!!!!!!!!!!!!!!!!!!!!!!!!!!!
