Phasing and two bunches
simona.bettoni
Post by simona.bettoni » 05 Aug 2014, 06:22
I have a distribution which is given by two different bunches. These are both in the same file. I would like to phase all the linac with respect to one of the two. I think I have to use the command first_is_fiducial, but I need to say to Elegant which is the first bunch. Have I to put the bunches in two pages? I do not find how to do it.
Thanks in advance,
Simona.
Re: Phasing and two bunches
Post by michael_borland » 05 Aug 2014, 08:30
Simona,
This is a bit tricky to set up. You have to use both first_is_fiducial=1 and reset_rf_for_each_step=0 in &run_setup, along with track_pages_separately=1 in &sdds_beam. The linac will be phased to the first bunch (there's no straightforward way in elegant to phase it to the second).
See attached example.
twoBunchPhasing.zip
(1.81 KiB) Downloaded 564 times
simona.bettoni
Post by simona.bettoni » 05 Aug 2014, 09:56
Thanks for your answer and the example. If I correctly understood you defined 3 gaussians of 1000 particles each. I have an Astra simulations with two "deformed" gaussian coming out and I do not know how to say to Elegant that one is bunch 1 and that the other one is bunch 2. I can separate them in time for sure and generate two files, but, how can I do the two pages? Is it enough I put two headers: one before each bunch or have I to do it differently?
Thanks again,
Simona.
Post by michael_borland » 05 Aug 2014, 10:09
Simona,
I generated two bunches (n_steps=2 in &run_control in makeBeam.ele).
For your case, try the following:
sddssort astraOutput.sdds -pipe=out -column=t \
| sddsbreak -pipe=in astraOutput2Page.sdds -gapin=t,amount=10e-12
This sorts the particles into time order, then breaks the file into pages when there is a gap of 10 ps in the time values. The file astraOutput2Page.sdds would be used with &sdds_beam. Adjust the 10e-12 value to suit your particular case.
If you already have the two bunches in two files, you can combine them using
sddscombine file1.sdds file2.sdds file3.sdds
then use file3.sdds with &sdds_beam
Alternatively, use
&sdds_beam
input_list = "file1.sdds file2.sdds"
track_pages_separately = 1
simona.bettoni
Post by simona.bettoni » 05 Aug 2014, 10:11
Perfect!
Many thanks,
Simona.
