elegant2astra conversion
jatuporn.saisut
Post by jatuporn.saisut » 02 Jul 2014, 14:12
Hi all,
I try to convert the output of Elegant to an input for Astra (using cygwin on windows7). I get message "elegant2astra: line 79: syntax error: unexpected end of file". What should I do?
Thanks for your help,
Jatuporn
Re: elegant2astra conversion
Post by michael_borland » 07 Jul 2014, 08:35
Jatuporn,
I'm not able to reproduce this error on linux. Which shell are you using in cygwin? You can find out by typing "echo $SHELL".
Post by soliday » 07 Jul 2014, 09:34
That message usually means that you have windows style carrage returns in the script. However on my system, even when I convert it to windows style carrage returns, it still works. Can you cd to the directory with elegant2astra and run "dos2unix elegant2astra" this will convert the carrage returns.
