how to limit the output to screen?
Is there a way to run elegant without having all the output print to the screen?
Re: how to limit the output to screen?
It can be done. Depending on which shell you use, the command is different.
For csh or tcsh, you can redirect the output into a log file using
% elegant inputfile >& logfile
For bash, you should use
% elegant inputfile 2>1 > logfile
(Please observe the spaces carefully.)
If you don't want to put the output in a file but just want to ignore it, use /dev/null instead of a filename for "logfile".
This should work fine on Linux, Unix, OS-X, and Cygwin.
helps a lot thank you!michael_borland wrote:It can be done. Depending on which shell you use, the command is different.
It just redirects the output to a file or /dev/null.
Is there any plan to support user to disable the output message using a flag?
Guobao
Guobao
Guobao,
That would be quite a job since elegant freely sends output to stdout and stderr from within subroutines.
We could probably add a flag that redirects stderr and stdout to /dev/null using freopen(), but I'm not sure if that answers your requirements.
shengb wrote:It just redirects the output to a file or /dev/null.
Guobao
The output to stdout and stderr provides many useful information and very helpful
when using the elegant as a standalone executable application.
It will cause some trouble if we make the elegant as a simulation server and run 24/7,
or even crash the server. I do have some experience on that and hope there is a plan
to have a selection to enable/disable the output.
Another solution might be add a flag such as
#ifdef LIBRARY
set_print_namelist_flags(1);
#else
set_print_namelist_flags(0);
print_namelist(...);
#endif
Then we can select the flag to enable/disable the output when we compile it.
But just as you mentioned, it would be a big job because the output distributes everywhere
in whole SDDS/Elegant code.
I am not sure which one is better.
Guobao
#ifdef LIBRARY
#else
#endif
Guobao
shengb wrote:Hi Michael,
#ifdef LIBRARY
#else
#endif
Guobao
Guobao,
I think my last message didn't post because of a large attachment.
It turned out to be very easy to add flags to divert output to a user-specified file (or /dev/null).
I'll send you something about it via private email so you can get the new source.
#ifdef LIBRARY
#else
#endif
Guobao
