Could you give an example of "insert_elements" usage please?
I can't make it work.
insert_elements
insert_elements
- insert_elements.tar.gz
- (5.97 KiB) Downloaded 476 times
Re: insert_elements
Thank you for trying our code.
In your insert_elements command, you need to add "skip=1" or some none zero number according to your problem.
The default value "skip=0" has no action to add element to the beamline.
aimin
aimin
Re: insert_elements
Thanks a lot!
It's quite hard to guess. Probably it makes sense to set the default "skip" to 1.
