When I attempt to use the &sdds_beam command to load in a particle distribution to pelegant, I get an error message:
Error:
Unable to read ascii file with SDDS_MPI.
The sdds file is valid (according to sddscheck); actually doing something with it (e.g. running sddsanalyzebeam on it) also works fine.
Converting it to binary via sddsconvert results in a normal run.
This error does not occur using an identical set of .ele, .lte and particle distribution file, when running elegant.
Command used:
&sdds_beam
input=op000044.dat
input_type="elegant"
The file op000044.dat contains 150k particles.
The computer is an 8-core Windows 7 machine.
- John L.
&sdds_beam in pelegant requires a binary input file.
Re: &sdds_beam in pelegant requires a binary input file.
John,
Yes, this is a known limtiation of our MPI I/O library. Sorry about that, but we assumed if someone was using the parallel, they wouldn't use the slow ASCII input method.
