Simplex Algorithm
MDP
Simplex Algorithm
Post by MDP » 26 Aug 2013, 09:09
The simplex optimization method is recommended in the elegant manual. I used it for the optimization of an extraction arc and it worked fine. However, I was wondering if you could tell my why the simplex method is recommended and not any other optimization algorithm. Is it the fact that this method does not require the derivatives of the optimization function which makes it faster and more stable?
Thank you in advance!
Matthias
Re: Simplex Algorithm
Post by michael_borland » 16 Sep 2013, 08:33
Matthias,
Mostly, it is recommended based on experience. It tends to find solutions more reliably than the other methods we've tried.
MDP
Post by MDP » 18 Nov 2013, 05:25
thanks for your help!
Matthias
