testing Pelegant on elegantExamples
marlibgin
Post by marlibgin » 15 Jul 2013, 11:22
I am testing Pelegant
[This is elegant 25.0.3, Mar 2 2012, by M. Borland, W. Guo, V. Sajaev, Y. Wang, Y. Wu, and A. Xiao.
Parallelized by Y. Wang, H. Shang, and M. Borland.]
on our local cluster. I have started with some examples taken from elegantExamples/parallel/DA,FMA,LMA. All worked fine. I then (maybe naively) tried to run another, randomly chosen case with Pelegant. I have picked up elegantExamples/acceptance/energyscan1 and submitted a job with Pelegant.
qsub -V -q ap-high.q -pe openmpi 4 /dls_sw/apps/openmpi/1.6.5/64/bin/mpirun Pelegant run.ele
The job crashed leaving a log file with this message:
Fatal error in PMPI_Bcast: Invalid root, error stack:
PMPI_Bcast(1478): MPI_Bcast(buf=0x993788, count=1, MPI_LONG, root=1, MPI_COMM_WORLD) failed
PMPI_Bcast(1440): Invalid root (value given was 1)
orterun noticed that the job aborted, but has no info as to the process
that caused that situation.
My question is. Can any of the elegantExamples be run with Pelegant, or are there some limitations on its use?
Concerning the error above, is there any advice/clue about it?
Thanks very much for the kind attention , Marco
Re: testing Pelegant on elegantExamples
Post by michael_borland » 16 Sep 2013, 08:04
Marco,
In general, all of the examples should work with Pelegant. I tried the one that gave you a problem and it ran fine. Did you have trouble with other examples?
tiansk
Post by tiansk » 14 Oct 2015, 01:07
I meet the same error
PMPI_Bcast(1606): MPI_Bcast(buf=0x9050e8, count=1, MPI_LONG, root=1, MPI_COMM_WORLD) failed
PMPI_Bcast(1568): Invalid root (value given was 1)
mpiexec noticed that the job aborted, but has no info as to the process
How to solve this problem?
Post by soliday » 14 Oct 2015, 09:50
I googled this message and it seems to be coming from using a different MPI implementation than the one it was compiled on. If you are using the openmpi then you need the elegant.openmpi RPM file. If you are using mpich then you need the elegant.mpich RPM file. These were built using the standard system libraries. If you are using a newer release of openmpi or mpich than the standard system libraries, it may or may not work. If it doesn't, you will need to use the Build_AOP_RPMs script and supply it with the path to mpicc for the version you are using.
tiansk
Post by tiansk » 14 Oct 2015, 21:25
On my computer,there are two mpiexec commands
/usr/bin
/home/tiansk/elegant/mpich2-1.1/bin/
the second one is in my account,that is the mpiexec command I wanted so
I changed the ~/.bashrc file and change the PATH.
The problem is resolved.
Thanks
tiansk
Post by tiansk » 15 Oct 2015, 20:47
I meet an other problem.
I test the Pelegant with the example
/home/tiansk/elegantExamples/acceptance/energyScan1
as follow,tThere is no error in the process of simulation
mpiexec -np 2 Pelegant run.ele
Running elegant at Fri Oct 16 09:27:24 2015
This is elegant 28.1.0, Jul 24 2015, by M. Borland, M. Carla', N. Carmignani, M. Ehrlichman, L. Emery, W. Guo, V. Sajaev, R. Soliday, C.-X. Wang, Y. Wang, Y. Wu, and A. Xiao.
Link date: Jul 24 2015 11:14:16
statistics: ET: 00:00:00 CP: 0.00 BIO:0 DIO:0 PF:0 MEM:20048
&run_setup
lattice = lattice.lte,
use_beamline = bl,
rootname = {NULL},
output = {NULL},
centroid = %s.cen,
sigma = %s.sig,
final = %s.fin,
acceptance = %s.acc,
losses = %s.los,
magnets = {NULL},
semaphore_file = {NULL},
parameters = {NULL},
combine_bunch_statistics = 0,
wrap_around = 1,
final_pass = 0,
default_order = 2,
concat_order = 0,
print_statistics = 0,
show_element_timing = 0,
monitor_memory_usage = 0,
random_number_seed = 987654321,
correction_iterations = 1,
echo_lattice = 0,
p_central = 0.000000000000000e+00,
p_central_mev = 1.000000000000000e+03,
always_change_p0 = 0,
load_balancing_on = 0,
random_sequence_No = 1,
expand_for = {NULL},
tracking_updates = 1,
search_path = {NULL},
element_divisions = 0,
Seeding random number generators (mode=3)
length of beamline BL per pass: 5.109999999999996e+01 m
statistics: ET: 00:00:00 CP: 0.00 BIO:0 DIO:0 PF:0 MEM:20155
&run_control
n_steps = 1,
bunch_frequency = 0.000000000000000e+00,
n_indices = 1,
n_passes = 1,
reset_rf_for_each_step = 1,
first_is_fiducial = 0,
restrict_fiducialization = 0,
reset_scattering_seed = 0,
&vary_element
index_number = 0,
index_limit = 21,
name = MALIN,
item = DP,
initial = -5.000000000000000e-01,
final = 5.000000000000000e-01,
differential = 0,
geometric = 0,
multiplicative = 0,
enumeration_file = {NULL},
enumeration_column = {NULL},
&bunched_beam
bunch = %s.bun,
n_particles_per_bunch = 1000,
time_start = 0.000000000000000e+00,
matched_to_cell = {NULL},
emit_x = 1.000000000000000e-06,
emit_nx = 0.000000000000000e+00,
beta_x = 1.000000000000000e+02,
alpha_x = 0.000000000000000e+00,
eta_x = 0.000000000000000e+00,
etap_x = 0.000000000000000e+00,
emit_y = 1.000000000000000e-06,
emit_ny = 0.000000000000000e+00,
beta_y = 1.000000000000000e+02,
alpha_y = 0.000000000000000e+00,
eta_y = 0.000000000000000e+00,
etap_y = 0.000000000000000e+00,
use_twiss_command_values = 0,
Po = 1.956950762296902e+03,
sigma_dp = 0.000000000000000e+00,
sigma_s = 0.000000000000000e+00,
dp_s_coupling = 0.000000000000000e+00,
emit_z = 0.000000000000000e+00,
beta_z = 0.000000000000000e+00,
alpha_z = 0.000000000000000e+00,
momentum_chirp = 0.000000000000000e+00,
one_random_bunch = 1,
save_initial_coordinates = 1,
limit_invariants = 0,
symmetrize = 0,
halton_sequence[0] = 0, 0, 0,
halton_radix[0] = 0, 0, 0, 0, 0, 0,
optimized_halton = 0,
randomize_order[0] = 0, 0, 0,
limit_in_4d = 0,
enforce_rms_values[0] = 0, 0, 0,
distribution_cutoff[0] = 1.000000000000000e+00, 1.000000000000000e+00, 2.000000000000000e+00,
distribution_type[0] = uniform-ellipse, uniform-ellipse, gaussian,
centroid[0] = 0.000000000000000e+00, 0.000000000000000e+00, 0.000000000000000e+00, 0.000000000000000e+00,
statistics: ET: 00:00:00 CP: 0.00 BIO:0 DIO:0 PF:0 MEM:20158
&track
center_on_orbit = 0,
center_momentum_also = 1,
offset_by_orbit = 0,
offset_momentum_also = 1,
soft_failure = 1,
use_linear_chromatic_matrix = 0,
longitudinal_ring_only = 0,
ibs_only = 0,
stop_tracking_particle_limit = -1,
vary counter reset
121 matrices (re)computed
tracking step 1.1
generating bunch 1.1
dumping bunch
0 matrices (re)computed after correction
tracking 1000 particles
16 Oct 15 09:27:24: This step establishes energy profile vs s (fiducial beam).
16 Oct 15 09:27:24: Rf phases/references reset.
188 particles transmitted, total effort of 188 particle-turns
125440 multipole kicks done
Dumping acceptance output...done.
Dumping lost-particle data...
n_left = 188, n_total = 1000, n_lost = 812
done.
Dumping centroid data...done.
Dumping sigma data...done.
Dumping final properties data...done.
Post-tracking output completed.
Tracking step completed ET: 00:00:00 CP: 0.07 BIO:0 DIO:0 PF:0 MEM:22770
counter advanced: 1
values advanced: -4.500000e-01
tracking step 2.2
206 particles transmitted, total effort of 206 particle-turns
257808 multipole kicks done
n_left = 206, n_total = 1000, n_lost = 794
done.
Tracking step completed ET: 00:00:00 CP: 0.12 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 2
values advanced: -4.000000e-01
tracking step 3.3
227 particles transmitted, total effort of 227 particle-turns
398168 multipole kicks done
n_left = 227, n_total = 1000, n_lost = 773
done.
Tracking step completed ET: 00:00:00 CP: 0.17 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 3
values advanced: -3.500000e-01
tracking step 4.4
241 particles transmitted, total effort of 241 particle-turns
545536 multipole kicks done
n_left = 241, n_total = 1000, n_lost = 759
done.
Tracking step completed ET: 00:00:00 CP: 0.22 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 4
values advanced: -3.000000e-01
tracking step 5.5
246 particles transmitted, total effort of 246 particle-turns
698176 multipole kicks done
n_left = 246, n_total = 1000, n_lost = 754
done.
Tracking step completed ET: 00:00:01 CP: 0.27 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 5
values advanced: -2.500000e-01
tracking step 6.6
16 Oct 15 09:27:25: This step establishes energy profile vs s (fiducial beam).
16 Oct 15 09:27:25: Rf phases/references reset.
257 particles transmitted, total effort of 257 particle-turns
855784 multipole kicks done
n_left = 257, n_total = 1000, n_lost = 743
done.
Tracking step completed ET: 00:00:01 CP: 0.34 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 6
values advanced: -2.000000e-01
tracking step 7.7
265 particles transmitted, total effort of 265 particle-turns
1018212 multipole kicks done
n_left = 265, n_total = 1000, n_lost = 735
done.
Tracking step completed ET: 00:00:01 CP: 0.39 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 7
values advanced: -1.500000e-01
tracking step 8.8
264 particles transmitted, total effort of 264 particle-turns
1182532 multipole kicks done
n_left = 264, n_total = 1000, n_lost = 736
done.
Tracking step completed ET: 00:00:01 CP: 0.45 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 8
values advanced: -1.000000e-01
tracking step 9.9
1348228 multipole kicks done
done.
Tracking step completed ET: 00:00:01 CP: 0.51 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 9
values advanced: -5.000000e-02
tracking step 10.10
267 particles transmitted, total effort of 267 particle-turns
1517400 multipole kicks done
n_left = 267, n_total = 1000, n_lost = 733
done.
Tracking step completed ET: 00:00:01 CP: 0.56 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 10
values advanced: 0.000000e+00
tracking step 11.11
275 particles transmitted, total effort of 275 particle-turns
1689476 multipole kicks done
n_left = 275, n_total = 1000, n_lost = 725
done.
Tracking step completed ET: 00:00:01 CP: 0.62 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 11
values advanced: 5.000000e-02
tracking step 12.12
281 particles transmitted, total effort of 281 particle-turns
1865240 multipole kicks done
n_left = 281, n_total = 1000, n_lost = 719
done.
Tracking step completed ET: 00:00:02 CP: 0.68 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 12
values advanced: 1.000000e-01
tracking step 13.13
16 Oct 15 09:27:26: This step establishes energy profile vs s (fiducial beam).
16 Oct 15 09:27:26: Rf phases/references reset.
2043620 multipole kicks done
done.
Tracking step completed ET: 00:00:02 CP: 0.75 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 13
values advanced: 1.500000e-01
tracking step 14.14
280 particles transmitted, total effort of 280 particle-turns
2224624 multipole kicks done
n_left = 280, n_total = 1000, n_lost = 720
done.
Tracking step completed ET: 00:00:02 CP: 0.82 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 14
values advanced: 2.000000e-01
tracking step 15.15
288 particles transmitted, total effort of 288 particle-turns
2409104 multipole kicks done
n_left = 288, n_total = 1000, n_lost = 712
done.
Tracking step completed ET: 00:00:02 CP: 0.88 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 15
values advanced: 2.500000e-01
tracking step 16.16
292 particles transmitted, total effort of 292 particle-turns
2595304 multipole kicks done
n_left = 292, n_total = 1000, n_lost = 708
done.
Tracking step completed ET: 00:00:02 CP: 0.94 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 16
values advanced: 3.000000e-01
tracking step 17.17
296 particles transmitted, total effort of 296 particle-turns
2782676 multipole kicks done
n_left = 296, n_total = 1000, n_lost = 704
done.
Tracking step completed ET: 00:00:02 CP: 1.01 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 17
values advanced: 3.500000e-01
tracking step 18.18
306 particles transmitted, total effort of 306 particle-turns
2972816 multipole kicks done
n_left = 306, n_total = 1000, n_lost = 694
done.
Tracking step completed ET: 00:00:02 CP: 1.08 BIO:0 DIO:0 PF:0 MEM:22816
counter advanced: 18
values advanced: 4.000000e-01
tracking step 19.19
312 particles transmitted, total effort of 312 particle-turns
3164708 multipole kicks done
n_left = 312, n_total = 1000, n_lost = 688
done.
Tracking step completed ET: 00:00:03 CP: 1.15 BIO:0 DIO:0 PF:0 MEM:22849
counter advanced: 19
values advanced: 4.500000e-01
tracking step 20.20
16 Oct 15 09:27:27: This step establishes energy profile vs s (fiducial beam).
16 Oct 15 09:27:27: Rf phases/references reset.
320 particles transmitted, total effort of 320 particle-turns
3358608 multipole kicks done
n_left = 320, n_total = 1000, n_lost = 680
done.
Tracking step completed ET: 00:00:03 CP: 1.22 BIO:0 DIO:0 PF:0 MEM:22849
counter advanced: 20
values advanced: 5.000000e-01
tracking step 21.21
326 particles transmitted, total effort of 326 particle-turns
3552768 multipole kicks done
n_left = 326, n_total = 1000, n_lost = 674
done.
Tracking step completed ET: 00:00:03 CP: 1.28 BIO:0 DIO:0 PF:0 MEM:22849
Finished tracking.
End of input data encountered.
statistics: ET: 00:00:03 CP: 1.28 BIO:0 DIO:0 PF:0 MEM:22846
Thanks for using Pelegant. Please cite the following references in your publications:
M. Borland, "elegant: A Flexible SDDS-Compliant Code for Accelerator Simulation,"
Advanced Photon Source LS-287, September 2000.
Y. Wang and M. Borland, "Pelegant: A Parallel Accelerator Simulation Code for
Electron Generation and Tracking", Proceedings of the 12th Advanced Accelerator
Concepts Workshop, AIP Conf. Proc. 877, 241 (2006).
If you use a modified version, please indicate this in all publications.
but,when I try to plot some pictures,I meet an error report.
sddsplot -column=x,y run.los -split=page -sep=page -graph=dot -samescales
warning: problem reading data from file run.los
Error:
Unable to read page--unrecognized data mode (SDDS_ReadPageSparse)
error: no datasets to plot
I think in the output file run.los,there is no data.
I run the command
in the cygwin on a windows computer,the program is running very well andthere are no error report!
Post by soliday » 16 Oct 2015, 10:21
What version of Linux are you using? I tried to figure it out from our download log but you've downloaded elegant for lots of different versions of Linux. I want to run the same version and run it against mpich2-1.1 to see what is going on.
tiansk
Post by tiansk » 16 Oct 2015, 20:00
I have two linux computers,the versions of Linux as follow:
Linux version 3.14-2-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.3 (Debian 4.8.3-7) ) #1 SMP Debian 3.14.15-2 (2014-08-09)
Linux version 3.10.0-123.el7.x86_64 (mockbuild@sbuilder.fnal.gov) (gcc version 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC) ) #1 SMP Thu Sep 11 15:55:14 CDT 2014
the elegant version installed respectively as follow:
elegant-28.1.0-1.debian.8.1.mpich.x86_64.rpm
elegant-28.1.0-1.rhel.7.mpich.x86_64.rpm
I used pelegnat to test examples :elegantExamples/parallel
Simulation program can be run perfectly!
I wonder:are there some files cannot be used Pelegant?
Post by michael_borland » 20 Oct 2015, 16:52
I tried that example (acceptance/energyScan1) with Pelegant 28.1.0 and had no problems. The plots seem fine.
tiansk
Post by tiansk » 20 Oct 2015, 20:39
The two attachment file are the output files using Pelegant with Debian Linux and Cygwin on Windows,with Cygwin, the output file is GOOD,the output file with Debian is not, two output file size is not consistent...
run_linux.acc
(283.55 KiB) Downloaded 4905 times
run_cygwin.acc
(296.26 KiB) Downloaded 4818 times
