genetic optimizer missing (perhaps)
alexdiazortiz
Post by alexdiazortiz » 03 May 2013, 03:02
Hi there,
I have installed elegant and sdds toolkit from rpm distributions (elegant-25.1.0-2.x86_64.rpm and SDDSEpicsToolKit-2.11-1.x86_64.rpm, respectively) on a 64-bit linux cluster (RHEL5, Intel). The installation went well without any error messages.
After the installation, I tried the mogaRing examples by following the instructions in the GuideToUse. In step 0, I ran into trouble because it seems that geneticOptimizer cannot be found: It is not in the elegant or SDDS installation directories. I wonder whether I am need to install some additional packages.
Any feedback will be appreciated. Thanks,
Alejandro
Re: genetic optimizer missing (perhaps)
Post by soliday » 03 May 2013, 09:12
You will need the SDDSToolKit which is different from the SDDSEpicsToolKit.
http://www.aps.anl.gov/asd/oag/download ... x86_64.rpm
You will also need OAGTclTk
Finally you will need our software scripts
http://www.aps.anl.gov/asd/oag/download ... .19.tar.gz
You will find the generic optimizer under:
oag/apps/src/tcltkapp/oagapp/optimizeInterface
Once you install the SDDSToolKit and the OAGTclTk package, you should be able to run the optimizeInterface program.
alexdiazortiz
Post by alexdiazortiz » 06 May 2013, 05:08
Thanks a lot for the info!
Regarding the oag scripts:Do I have to "make" them? Or just put them in the path?
Sorry for the all-rookie questions.
Thanks.
Alejandro
Post by soliday » 06 May 2013, 09:21
The oag scripts just need to be put in your path. The package that we have on the web is just our source tree.
alexdiazortiz
Post by alexdiazortiz » 07 May 2013, 03:03
Thanks!
