find_aperture throws SIGSEG
Julian
Post by Julian » 27 Mar 2013, 03:33
i have not found any hint on how to get find_aperture working with Pelegant. Everytime i start my job, even this minimalistic attached one, the last line on the log is:
Terminated by SIGSEGVProgram trace-back:
The process is still running on all cores, but there seems to be no progress. That's why i cancel that job.
Is there a work-around for this problem or is find_aperture not suitable for Pelegant or what am i doing wrong?
Thanks a lot
Julian
parallel-error.log
Log of a run
(3.7 KiB) Downloaded 3892 times
parallel-error.lte
Lattice file
(4.16 KiB) Downloaded 4046 times
parallel-error.ele
Minimalistic Elegant file
(263 Bytes) Downloaded 3112 times
Re: find_aperture throws SIGSEG
Post by michael_borland » 27 Mar 2013, 07:54
Julian,
The recommended mode for parallel elegant is "n-line", which works fine for parallel and serial modes. The code is actual *supposed* to exit with an error message when other modes are used, since they have not been parallelized.
By the way, you need not define a beam (&bunched_beam) for &find_aperture. It isn't related.
Julian
Post by Julian » 27 Mar 2013, 10:14
Thank you.
Now this works with mode="n-lines". I'm sorry for taking your time.
Post by michael_borland » 27 Mar 2013, 10:19
No problem. Sorry for the bug and lack of clarity in the documentation.
