WATCH filename bug report
lewellen
Post by lewellen » 13 Mar 2013, 15:42
This is a bug report for the WATCH element filename.
I'm using elegant version 25.1.0, running on a Windows 7 machine.
Here's a small fragment of the lattice file; the elegant command file is MaRIE.ele
look: watch, filename=<filename goes here>
MaRIE: line=(bunchCharge,pMatch,&
look, LIN.BC, look, L01.SMLS)
I'm getting odd results - including crashes - when attempting to use the rootname filename and counter options for this element.
If I set filename="test.watch", elegant runs fine and I see a file called test.watch in my directory. That works fine.
If I set filename="%s.watch", elegant runs fine and I see a file called MaRIE.watch in my directory. Also fine.
If I set filename="%s-%ld.watch", elegant runs fine and I see two files called MaRIE-1.watch and MaRIE-2.watch. Also fine.
If I set filename="%s-%03ld.watch," elegant crashes quietly as soon as it gets to the first watch point - no error messages, just stops.
If I set filename="%s-%03ld.wat," elegant runs fine and I get MaRIE-001.wat and MaRIE-002.wat in the output directory.
So, there appears to be a bug related to long filename extensions when using the incomplete filename specification to get the occurrence number in the filename.
Cheers,
- John L.
To wit, if I set filename="whatever.watch" I get a single watch file called whatever.watch.
If I set filename="%s.watch" I get a single filename called
Re: WATCH filename bug report
Post by michael_borland » 15 Mar 2013, 18:08
John,
Thanks for reporting the bug. I'll try to resolve it before the next release.
Post by michael_borland » 17 Mar 2013, 15:05
John,
I'm unable to reproduce this bug. Could you post a set of files that demonstrate the problem?
