modulate_elements and ramp_elements bug
Post by michael_borland » 06 Feb 2013, 13:50
There is a bug in modulate_elements and ramp_elements that results in only the first occurrence of an element of a given name being affected by the command. Until this is resolved, care should be exercised in using these commands. The best strategy is to give different names to all the elements that will be modulated or ramped.
Thanks to Ray Fliller for reporting this problem.
Re: modulate_elements and ramp_elements bug
Post by michael_borland » 06 Feb 2013, 14:25
For those who build from source, use the attached files to get the bug fix. This will also appear in the next release.
fix.tar.gz
(41.06 KiB) Downloaded 437 times
