modulate_elements
fliller
modulate_elements
Post by fliller » 06 Feb 2013, 09:16
I am attempting to do a simulation where I vary quadrupoles with time while tracking particles. I am using modulate_elements to vary the quadrupoles. I does not seem to be working however. Attached is the lattice file and a file called Tester.ele. Tester.ele produces the results that I expect when I look at the output of the watchpoint. DoTuneVariation_OCtopole.ele attempts to do the same thing using modulate_elements. The file that defines the quad strength is QuadScan.sdds, and just sets the quads to a constant value. Evcept for how the tune is changed, the two files should be identical (I think).
Am I doing anything wrong?
Ray
ForMike.zip
(3.38 KiB) Downloaded 547 times
Re: modulate_elements
Post by michael_borland » 06 Feb 2013, 10:02
Ray,
It think if you set "refresh_matrix=1" in the &modulate_elements commands you should see the expected behavior.
Basically, elegant is not set up to recalculate the element's matrix as modulation is performed, because some elements have a matrix that isn't used for tracking. Kind of tricky, I know.
fliller
Post by fliller » 06 Feb 2013, 12:10
I tried that with version 25.0.2 and it did not work. So I upgraded to 25.1, and it still did not work.
Ray
Post by michael_borland » 06 Feb 2013, 12:15
Ray,
Your QuadScan.sdds file has no variation in the qf or qd columns
% sddsprintout -format=double=%21.15e -col QuadScan.sdds
Printout for SDDS file QuadScan.sdds
          time                    qf                     qd
 0.000000000000000e+00  2.073075000000000e+00  -1.362636000000000e+00
 5.283655000000000e-04  2.073075000000000e+00  -1.362636000000000e+00
 1.056731000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
 1.585097000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
 2.113462000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
 2.641828000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
 3.170193000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
 3.698559000000000e-03  2.073075000000000e+00  -1.362636000000000e+00
fliller
Post by fliller » 06 Feb 2013, 12:31
Correct. But you will notice that it is different than the lattice file. The lattice is set to a tune of 9.64. The Tester.ele adjusts the tunes of the lattice to 9.751 and then tracks.
The other file sets the quads to the values with should give a tune of 9.751 and then tracks. I'd expect that the tracking output of both .ele files would be identical for the posted case, and they are not.
Ray
Post by michael_borland » 06 Feb 2013, 13:36
Ray,
There appears to be a bug. I'm looking into it to see if there is a workaround.
Post by michael_borland » 06 Feb 2013, 13:48
Ray,
The problem is that the code is only set up to modulate the first element of any group of elements with the same name. Until I can fix this, you'll need to give each modulated element a different name and include a &modulate_elements command for each. Alternatively, if you give names like "QF001", "QF002", etc., it should work to give one &modulate_elements command with name="QF0??".
fliller
Post by fliller » 06 Feb 2013, 14:20
I gave all of the elements names like QF01, QF02, etc. Then I tried the QF0? trick. That did not work, either giving me a SegV or another error. But if I give a separate &modulate_elements for each QF, then it is golden.
Thanks for the help/hack.
Ray
Post by michael_borland » 06 Feb 2013, 14:26
Ray,
I posted a fix for this bug under the Bugs topic. If you build from source, that should get you going.
If not, I hope to release the next revision in a few weeks.
Post by michael_borland » 06 Feb 2013, 14:36
Ray,
Glad to hear the hack worked.
Can you send me the input files for the separated-names case? It will make a good addition to my regression tester.
