Are ECOL and RCOL always centered on the reference trajectory? When I insert
such a collimator in a dispersive section, I loose most of the particles.
Thanks for any help.
-- Philippe.
Attachment: example; see .png pics for with and without collimator cases
question on ECOL and RCOL
Philippe Piot
- COL.tar
- (200 KiB) Downloaded 665 times
Re: question on ECOL and RCOL
Philippe,
By default, collimators are centered on the reference trajectory.
The problem I see with your run is that p_central=26.19 in run_setup, but sddsanalyzebeam tells me that your beam has <p> = 22.98. So when the beam goes through the chicane, it has a large trajectory offset and hits the collimator.
An easy way to prevent this kind of error is to let elegant determine p_central for your beam using the "expand_for" feature:
&run_setup
expand_for = <beamFileName>
It is a little inefficient in that the beam file is read twice (once by run_setup and once later by sdds_beam). However, that isn't a worry unless the beam file is huge.
&run_setup
