Mike,
I would like to use the Mapsolenoid element to track through a solenoid. The format is the SDDS file is unclear to me. It looks like 4 columns Bz, Br, z and r. The thing that confuses me is "Each page should have values for fixed r". Is there an example of how to use this element? Thanks.
Ray
MapSolenoid
Re: MapSolenoid
Ray,
Please see attached.
- solenoid.sdds
- (78.09 KiB) Downloaded 673 times
Re: MapSolenoid
Thanks. Now I'm trying to get that file to work and I get "****Error: determineMatrix called for element that is not supported! ***Seek professional help!"
Attached are my files..... Just tracking through Solenoid.sdds do see that I can get everything else correct....
This is not the first time I've been told to get professional help!
Ray
Ray
- TrackSolenoid.ele
- (546 Bytes) Downloaded 712 times
- SolenoidMap.lte
- (186 Bytes) Downloaded 700 times
Re: MapSolenoid
Ray,
Yes, it turns out there is a bug. I don't see a workaround for it. If you are using 64 bit linux or build from source, I can give you a patch. Otherwise, it will take a little while to roll one out.
