bug fix for parallel version RFCA
Post by michael_borland » 14 Aug 2008, 07:40
Wangming Liu found a problem with RFCA when fiducial mode is set to "pmaximum" in parallel elegant. This was fixed by Yusong Wang. I'm attaching a revised version of simple_rfca.c for those who build from source (actually the only option for parallel elegant at this point).
A new release of elegant (19.1) will be out in a few days. However, this bug fix came too late for inclusion in that release. Hence, the attached file should be used even with the 19.1 release. It will be included in the 19.2 release.
simple_rfca.c
(25.23 KiB) Downloaded 1416 times
