I am designing a transfer line, a linac and another transfer line. Each of them is quite complicated and I would like to keep them separate in different folders.
Is there a way to import the 6D beam distribution that I have saved with a WATCH element at the end of one section, into the following section? I would like to be able to track the non-linearities along the full complex.
Thanks
-Dario
Import beam distribution
Re: Import beam distribution
Dario,
Yes, you can do this using the &sdds_beam command. It with track the output of a WATCH element or the file created with the &run_setup output=<filename> feature.
