I had a fresh install of elegant compiling from the source yesterday. Now I'm running some examples and studying the manual to get familiar with it.
A very interesting tool I would like to use is view3dGeometry. The script has been correctly installed with elegant, but when I run it, it complies that oagtclsh is not present. I have not found any kind of documentation explaining where to get it and how to install.. Can you please tell me something about?
Thank you
oagtclsh. Where to get it?
Re: oagtclsh. Where to get it?
You can get this from the software download page at
http://www.aps.anl.gov/Accelerator_Syst ... ware.shtml
Look for "Tcl/Tk"
Look for "Tcl/Tk"
I have been looking around for much time, but I've not been able to figure out how to compile this from the source. I can't find any reference to this in the Linux Installation guide. Any help would be much appreciated.
Thank you!
Thank you!
It is very complicated to compile from source code. The preferred method is to install the linux RPM. If you are on a 64 bit linux computer try installing:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... x86_64.rpm
If you are on a 32bit computer you can use:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... 6.i386.rpm
If either of these won't don't work on your version of Linux, then let me know what version you are using any I will try to compile a version of oagtclsh for you.
Thank you soliday, I'm running a 64bits ArchLinux. I think that somehow this (fantastic) distribution can also install RPM. I will try to follow this way.
Best regards
Best regards
