Bug for non-zero length ECOL element with offset
Post by michael_borland » 05 Mar 2012, 12:28
There is a a bug for the ECOL element if the length is non-zero and the offset (DX or DY) is nonzero.
Three workarounds are possible:
* Use RCOL, if possible.
* Use a pair of ECOL elements separated by a drift space that is equal to the desired ECOL length.
* Instead of misaligning the ECOL element using the DY or DX parameters, bracket the ECOL by two MALIGN elements, as in
dyn: malign,dy=-0.02
dyp: malign,dy=0.02
col: ecol,...
bl: line=(dyn,col,dyp)
Re: Bug for non-zero length ECOL element with offset
Post by michael_borland » 05 Mar 2012, 12:32
Here's the corrected source code for those who build from source.
limit_amplitudes.c
(28.05 KiB) Downloaded 479 times
