divide and inserting elements
Max
Post by Max » 08 Dec 2011, 16:13
Hi Michael and collaborators,
are you aware of an optics problem when splitting SBEN in 2 sections with divide_elements and inserting another element (a kicker of zero length and strength) in between
the 2 sections (insert_elements) ? The tunes seem to change when I do that, as compared to not splitting the SBEN and not inserting the kicker.
Thanks, best regards, Max
Re: divide and inserting elements
Post by michael_borland » 09 Dec 2011, 09:30
Max,
I'm surprised by this. I did a test with a lattice containing a large-angle dipole and I didn't see any change. Can you post an example file?
Max
Post by Max » 09 Dec 2011, 10:36
in that case, I am sure I am doing something wrong...
I attach two .ele files (divided and undivided dipoles) and the .lte file.
I find:
divided dipoles: nux=6.739, nuy=6.845
undivided dipoles: nux=7.356,nuy=6.519
Thanks a lot,
Max
umer.lte
(25.79 KiB) Downloaded 557 times
undiv.ele
(594 Bytes) Downloaded 598 times
div.ele
(754 Bytes) Downloaded 585 times
Post by michael_borland » 09 Dec 2011, 13:40
Max,
Actually, it was my mistake. My test wasn't valid.
There is a an issue here. You can workaround it by turning off the edge effects on the interior parts. To do this, add the following statements after the &replace_elements command:
&alter_elements name=B*, type=SBEN, item=EDGE2_EFFECTS, value=0, start_occurence=1, end_occurence=1, verbose=1 &end
&alter_elements name=B*, type=SBEN, item=EDGE1_EFFECTS, value=0, start_occurence=2, end_occurence=2, verbose=1 &end
Max
Post by Max » 09 Dec 2011, 14:36
Thank you Michael. It works.
Best regards, Max
