Hi-
I noticed that the divide_elements command works for CSRDRIF but not CSRCSBEN. In the elegant manual it says that divide_elements can only be applied QUAD, SBEN, RBEN, DRIF, and SEXT. Is it possible to have divide_elements extended to cover the CSRCSBEN element?
Thanks
Spencer
Divide elements for CSRDRIF and CSRCSBEN
Re: Divide elements for CSRDRIF and CSRCSBEN
Spencer,
It would be difficult to provide this capability because elegant doesn't know how to propagate CSR from one bend to another.
If you want information from inside the CSRCSBEND, try the OUTPUT_FILE and PARTICLE_OUTPUT_FILE parameters. They may give you what you need.
