St and Ss for on ultrarelativistic bunches
Philippe Piot
Post by Philippe Piot » 22 Aug 2011, 08:19
I am using elegant at low energy gamma~10 (for some tests ignoring space charge). I am attaching a typical output file (fin and out) I noticed that
sddsprintout -parameter=Ss -parameter=St -parameter=pAverage parmelabeamfwd.fin
Printout for SDDS file parmelabeamfwd.fin
Ss (m) = 2.163954e-09 St (s) = 1.025654e-15 pAverage (m$be$nc) = 1.222129e+01
Should not there be a beta factor only between Ss and St?
-- Philippe.
parmelabeamfwd.fin
final parameter
(12.73 KiB) Downloaded 2015 times
parmelabeamfwd.out
output distribution
(14.55 KiB) Downloaded 1884 times
Re: St and Ss for on ultrarelativistic bunches
Post by michael_borland » 22 Aug 2011, 08:34
Philippe,
The relationship between St and Ss is not always simple. Ss is defined as the standard deviation of the distance traveled, whereas St is defined as the standard deviation of the arrival time. These are only related by the factor <beta>*c if the energy spread is sufficiently small.
