Microbunch instability simulation
simona.bettoni
I am looking to the function described in the "Specialized tools for Elegant" smoothDist6. I have other functions which are in the same package, like astra2elegant, so I suppose I downloaded the right group of files. Where can I download it?
Thanks.
Thanks.
Re: Microbunch instability simulation
The actual name of the program is smoothDist6s. It is included with the Linux RPM packages. Which operating system are you using?
simona.bettoni
Thanks a lot for your answer: now I have it running under Linux.
simona.bettoni
I would like to reduce the noise in the Elegant runs. I am presently using the LSC_LOW_FREQUENCY_CUT_OFF0 and LSC_LOW_FREQUENCY_CUT_OFF1, which I am putiing at 0.25 and 0.20 respectively. Is this wrong? Because when I am using them the simulation crashes saying:
"tracking 200000 particles
*** glibc detected *** elegant: realloc(): invalid pointer: 0x000000001f652070 *** ======= Backtrace: ========= [0x6b97dd] [0x5e4f91] [0x567334] [0x50b11b] [0x50d401] [0x47d9c9] [0x431b68] [0x48ad61] [0x697809] [0x4001e9] ======= Memory map: ========
00400000-007d2000 r-xp 00000000 00:16 2132544 /gpfs/homefelsim/bettoni_s/elegant/aps_oag/elegant
009d1000-00a04000 rw-p 003d1000 00:16 2132544 /gpfs/homefelsim/bettoni_s/elegant/aps_oag/elegant
00a04000-00a70000 rw-p 00a04000 00:00 0
1f55a000-2067b000 rw-p 1f55a000 00:00 0 [heap]
2b98acfab000-2b98ae05b000 rw-p 2b98acfab000 00:00 0
7fffb94c3000-7fffb94e4000 rw-p 7ffffffdd000 00:00 0 [stack]
7fffb95fc000-7fffb9600000 r-xp 7fffb95fc000 00:00 0 [vdso]
ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0 [vsyscall]
Terminated by SIGABRT
Program trace-back:
Thanks for any help or suggestions,
Simona.
Program trace-back:
Simona.
Simona,
Sorry about the crash.
The LSC_LOW_FREQUENCY_CUTOFF0 value should be less than the LSC_LOW_FREQUENCY_CUTOFF1.
Also, LSC_HIGH_FREQUENCY_CUTOFF0 and LSC_HIGH_FREQUENCY_CUTOFF1 are more important for controlling noise.
simona.bettoni
Thanks, now it's ok.
Simona.
Simona.
simona.bettoni
for the first part of the injector I am using Opal. I have 50 millions lines file in the h5 format from this. I wrote a small Matlab script to read, convert and write them in a file (binary) to use them as the input distribution for Elegant. I don't know how to produce a file which is usable by Elegant. Does Elegant accept only a ascii file?
Thanks for your comment,
Simona.
Simona.
Simona,
Elegant accepts either binary or ASCII SDDS files for the particle input. With 50 million particles, binary is strongly recommended as ASCII will be very slow. A description of the input columns is available under the documentation for the &sdds_beam command:
http://www.aps.anl.gov/Accelerator_Syst ... ode64.html
You can write SDDS files from MATLAB following the instructions here:
http://www.aps.anl.gov/Accelerator_Syst ... tlab.shtml
Another alternative is to use MATLAB to make a flat binary file, then convert it using plaindata2sdds. See
http://www.aps.anl.gov/Accelerator_Syst ... ode34.html
Finally, you can write the binary SDDS data by custom coding it in MATLAB. The binary file protocol is described here
http://www.aps.anl.gov/Accelerator_Syst ... ode10.html
With so many particles, I assume you are using the parallel version of elegant. If not, it is strongly recommended.
simona.bettoni
Thanks for the very quick answer.
I have another question... I run a scan over the wavelength and the amplitude for several number of particles. I put a the low pass filter in the simulation (0.20 and 0.25 parameters). For the output did you use a smoothing? sddsdigfilter? Do you suggest something better?
Simona.
Simona.
Simona,
To get the gain curve, I used the procedure described in http://prst-ab.aps.org/onecol/PRSTAB/v11/i3/e030701, page 8. I'm attaching my script, which might be helpful.
- processHistograms.tar
- (10 KiB) Downloaded 1257 times
