optimization using U1666
MDP
Post by MDP » 18 May 2011, 05:06
Hi all,
is it possible to optimize the third order dispersion of a lattice? I tried:
&optimization_term term = " MD3E#1.U1666 0 1e-1 sene " &end
but it didn't work. The matching was interrupted and the following message was posted:
Computing twiss parameters for optimization
Tracking for optimization
unknown token: MD3E#1.T1666
too few items on stack (divide)
*stop*
Problem evaluating expression: MD3E#1.U1666 0 1e-1 sene
RPN expression errors prevent optimization
I used
default_order=3,
in &run_setup and
matrix_order = 3,
in &optimization_setup
The marker MD3E#1 should not be the problem because it works properly for R16 and T166.
Does one of you know how to fix this?
Many thanks in advance for your help!
Matthias
Re: optimization using U1666
Post by michael_borland » 19 May 2011, 12:59
Matthias,
Unfortunately elegant doesn't presently allow fitting with interior values of Uijk. It was simple to add, so if you build from source you can use the attached file to make a version that includes this feature.
Otherwise, you can try breaking up your beamline, since fitting with final values of Uijk should work.
do_tracking.c
(158.61 KiB) Downloaded 2296 times
MDP
Post by MDP » 19 May 2011, 13:02
thanks for your help!
Matthias
