CLEAN in Pelegant
ding
CLEAN in Pelegant
Post by ding » 20 Apr 2011, 12:48
I noticed that if I set CLEAN such as CLEAN, DELTALIMIT =1.5, it won't work with Pelegant, though works well in Elegant. However, put a larger number like CLEAN, DELTALIMIT=1.8 it works. I am confused with it.
thanks,
Yuantao
Re: CLEAN in Pelegant
Post by michael_borland » 21 Apr 2011, 07:58
Yuantao,
Can you post some files that show the problem so I can test it more easily?
Thanks--Michael
ding
Post by ding » 21 Apr 2011, 17:32
while I set up a very simple example, it works for both elegant and Pelegant. I need some time to look into it first before asking help again.
thanks,
Yuantao
ding
Post by ding » 27 May 2011, 13:52
I uploaded an example, where RCOL is used in the middle of the chicane. When run Pelegant, i can have output at the location after the RCOL, and also at the end of the chicane. But actually the Charge parameter was not correct in the watchout files (still 20pC as before collimation). But after that, it won't continue to run into the following linacs. This is similar with CLEAN element I met. When there is a large amount of particle loss, it seems Pelegant has problems.
For the same setup runing with Elegant, everything works correctly.
thanks,
Yuantao
LCLS.lte
lattice file
(10.12 KiB) Downloaded 1726 times
LCLS.ele
ele file
(1.42 KiB) Downloaded 1706 times
BC1BEG.out
input beam file
(707.08 KiB) Downloaded 1740 times
ywang25
Post by ywang25 » 31 May 2011, 08:34
Yuntao,
Can you upload the wake files:
ZWAKEFILE="/afs/slac.stanford.edu/u/rl/ding/elegant/wakefiles/Sz_p05um_10mm.sdds", &
TRWAKEFILE="/afs/slac.stanford.edu/u/rl/ding/elegant/wakefiles/Sx_p05um_10mm.sdds", &
Yusong
ywang25
Post by ywang25 » 31 May 2011, 08:53
Yuntao,
I realized you were using the AFS file system. Please be aware the AFS is not listed as a supported file system for parallel I/O, which is required for the latest version of Pelegant.
You can see previous discussions at:
viewtopic.php?f=18&t=161&p=583&hilit=afs#p583
Yusong
ding
Post by ding » 31 May 2011, 11:37
Hi Yusong,
You may try with this uploaded lte file, where I removed the wakes. If I also remove the LSC, then it works. It looks to me Wakes or LSC will cause trouble, and they are both related with Charge.
I realized I can not work Pelegant on AFS for writing purpose. So I work with NFS, and only these wake files are saved in AFS space for read only. Without the CLEAN of RCOL element it works fine in my NFS.
thanks,
Yuantao
LCLS.lte
new .LTE file without wake files
(9.62 KiB) Downloaded 1756 times
ywang25
Post by ywang25 » 01 Jun 2011, 13:15
Yuantao,
You can use the attached file to replace the file under the elegant directory for the version 24.0 to fix the charge issue. The problem is caused by the delay of updating the total particle number across all the processors for minimizing communication overhead. The incorrect charge happens only in the intermediate output files and it would not affect the correctness of the final output. Unless you use the intermediate output file as the input of the next step, it should not cause a problem. Let me know if you find other issues.
Yusong
do_tracking.c
(156.05 KiB) Downloaded 1792 times
ding
Post by ding » 01 Jun 2011, 13:37
Thank you Yusong. Do I need to re-compile the Pelegant after replacing the file?
Yuantao
ywang25
Post by ywang25 » 01 Jun 2011, 13:43
You do need recompile the code. The fix I just provided should only affect the watch point output file. I will provide a better fix soon.
Yusong
