track momentum aperture+calculation of Touschek lifetime
pjchou
Post by pjchou » 25 Jul 2008, 02:38
This is an example on how to track momentum aperture in a storage ring, then calculate the Touschek lifetime. An elliptical beam pipe of 68 mm*30 mm is assumed in the lattice file. The procedure was set up with help from Michael. Thanks a lot :D
Ping
The shell script 'plotMomAperture' generates the plot of momentum aperture from the SDDS file "%s.mmap". The magnet layout is provided by the file "%s.mag". For TPS storage ring lattice, it takes about 4 hours to track the momentum aperture on ASUS W5 notebook PC.
***{ description of files}***
79h2Twiss.lte= input lattice used by the 'elegant' input file
79h2MomAperture3.ele= input file for 'elegant', sync radiation included.
plotMomAperture= script file for plotting momentum aperture
tpsTouschek= script file for the calculation of Touschek lifetime by using the SDDS output from tracking of momentum aperture.
plotMomAperture.txt
script file to plot momentum aperture
(398 Bytes) Downloaded 8312 times
input file for elegant, sync rad. included
(945 Bytes) Downloaded 8287 times
79h2Twiss.lte
lattice file for storage ring, elliptical beam pipe is assumed for the whole ring
(3.64 KiB) Downloaded 8198 times
Re: track momentum aperture+calculation of Touschek lifetime
Post by michael_borland » 25 Jul 2008, 13:01
Ping,
Thanks for posting the example.
I recommend using the attach lattice file instead of the one you posted. It has synchrotron radiation (classical only, no ISR) enabled, which gives more reliable determination of the momentum aperture.
79h2Twiss.lte
(3.79 KiB) Downloaded 8321 times
