Hello everyone,
Is there anyone who uses "frequency_map" to calculate the frequency map in the (x,delta) phase space?
I followed the manual to do it by
"&frequency_map
output = %s.fma
xmin = -0.02
xmax = 0.02
delta_min = -0.03
delta_max = 0.03
nx = 21
ndelta = 8
verbosity = 1
include_changes = 1
&end"
But the error comes as:
error: unknow variable delta_min used in namelist frequency_map
know variables are: output xmin xmax ymin ymax nx ny verbosity include_changes
Is anybody having the same problem? Or I made some mistake?
Thanks for your help.
Fanglei
frequency map
Re: frequency map
Fanglei,
It seems you may be using an older version of elegant. Can you check that you have the latest release, which is version 24.0 ?
Lin.fanglei
Re: frequency map
Thanks a lot, Michael, I'll ask our cluster manager to do it tomorrow.
Fanglei
Fanglei
