Hey everybody,
I would like to tell elegant, that it should not print out anything into the terminal while running. I'm talking about the command lines of the *.ele file as well as the "computed value for ..." stuff corresponding to the lattice. It should just be quiet. Is this possible? Thanks,
Thorsten
no printout in terminal
Re: no printout in terminal
Thorsten,
This can be done by putting the following at the top of the command file:
&global_settings
echo_namelists = 0,
log_file = "/dev/null"
error_log_file = "/dev/null",
The /dev/null is for Linux. I'm not sure what the null device would be for windows or mac.
You probably want to ask for a semaphore file to be created so you can verify that the run works:
&run_setup
semaphore_file = %s.done
&global_settings
echo_namelists = 0,
&run_setup
/dev/null can be used for mac as well.
NUL can be used for Windows.
Yusong
Yusong
