There is a bug in the momentum_chirp feature for bunched_beam. Please use the dp_s_coupling parameter instead. This impacts version 23.1, but not earlier versions. The symptom is that the transverse emittances will be wrong.
Thanks to Paul Emma for reporting the bug.
momentum_chirp bug (bunched_beam)
Re: momentum_chirp bug (bunched_beam)
This bug was fixed in version 24.1
