Emittance again
CCH
Emittance again
Post by CCH » 20 Jul 2010, 02:37
Mr Borland
I changed my lattice and get a new one with beta functions under 30 meters.The Ecny is good enough,But the Ecnx still changed a lot when I set the default_order=2 in run_setup.I can't understand why this happened.
-------------CCH
erl.ele
(1.68 KiB) Downloaded 965 times
erl.lte
(1.5 KiB) Downloaded 1113 times
Re: Emittance again
Post by michael_borland » 20 Jul 2010, 08:24
The reason is presumably that you have a large beam size in the second dipole, which has a very short bending radius rho. In second order, the equation of motion for x has a term x^2/rho. This term looks like a sextupole and is probably responsible for the emittance growth. Try reducing the beam size in the dipole magnets, or using longer dipoles to increase rho.
