matching workflow
tennant
matching workflow
Post by tennant » 28 May 2010, 11:32
If I am construct, for example, a FODO cell and ask Elegant to find the matched Twiss parameters, what is the best way to access those values? For example, I then want to fit to those values and do that within a single .ele file without having to look up matched parameters, manually put them into the .ele and run the optimizer.
chris
Re: matching workflow
Post by michael_borland » 28 May 2010, 13:15
Chris,
The best way to do this is using using rpn_load. See the attached example.
injRingMatch2.tar
(20 KiB) Downloaded 486 times
