sddsemitproc including dispersion
mjoyce
Post by mjoyce » 24 Mar 2010, 11:12
Can you please tell me what I'm doing wrong here?
We suspect that there is dispersion leakage that is affecting the X emittance, so we wanted to try out the -includeDispersion option. Assuming sddsemitproc removes the dispersion contribution, I would expect a smaller emittance. Rather than larger.
One mistake may be the dipole that I included in the line for the -includeDispersion option. The matrix elements start_from that dipole. Should I start farther upstream?
If you're willing to look into this, email me for other relevant files. The forum wouldn't let me attach > 3
Thanks.
Michele Joyce
TJNAF
input.sdds
This sdds file is what's passed to sddsemitproc WITHOUT the -includeDispersion option
(5.87 KiB) Downloaded 419 times
input.dpp.sdds
This sdds file is what I'm passing sddsemitproc and using the -includeDispersion option. It includes R16 and R36
(7.16 KiB) Downloaded 423 times
Re: sddsemitproc including dispersion
Post by michael_borland » 24 Mar 2010, 17:22
Michele,
Sorry for the delay in responding.
The -includeDispersion option is not reliable. It is actually disable in the most recent release. It attempts to determine the energy spread, but doesn't succeed well even in ideal cases. I think the problem is degenerate because the energy spread is a fixed quantity.
My suggestion is to subtract the dispersion contribution (in quadrature) from the beam sizes before. This requires that you know the energy spread already from a separate measurement.
Post by michael_borland » 24 Mar 2010, 17:43
Michele,
It might work if you have significant dispersion at the location of one of the quadrupoles you vary.
mjoyce
Post by mjoyce » 25 Mar 2010, 06:42
Thanks for the reply. We'll try the subtraction method.
