tracking get slower when using multiple watch
lyyang
Post by lyyang » 15 Dec 2009, 17:57
Hi All,
When I use 2-3 watch to record the beam position, I found the tracking is significantly slower, the data is only for 200 turns, should not be a problem, I have set output_at_each_step=0.
Is there any other options to control this I may not set it right ?
Does anyone have similar experience ? Thanks.
My ele looks like this:
&run_setup
lattice = "mv15-MB.lte",
use_beamline = RING,
magnets = %s.mag,
p_central_mev = 3000.0,
default_order = 3,
random_number_seed = 9784782334,
final = "%s.fin",
parameters = "%s.par",
&run_control
n_steps = 1,
n_indices=0,
n_passes = 200
&twiss_output
filename = "%s.twi",
statistics=1,
output_at_each_step=0,
radiation_integrals=1,
&alter_elements
name=MA1, item=DP, value=-0.025,name=MA1,item=DX,value=-0.015
!! DWKMM: MAXAMP, X_MAX=0.03, Y_MAX=0.005
&alter_elements
name=DWKMM, item=X_MAX,value=0.03,
name=DWKMM, item=Y_MAX,value=0.05
!&bunched_beam
!! centroid[6]={0.020, 0, 0.01, 0.001, 0.0, 0}
!&end
!&track &end
&find_aperture
output = "%s.aper",
mode = "n-lines",
xmin = -0.04,
xmax = 0.04,
ymin = .0,
ymax = 0.01,
nx = 21,
ny = 11,
n_splits = 9,
split_fraction = 0.2,
n_lines = 5,
verbosity = 1,
!&bunched_beam &end
!&track &end
!&run_setup
! lattice = "mv15-MB2.lte",
! lattice = "fodo.lte",
! use_beamline = RING,
! magnets = %s.mag,
! p_central_mev = 3000.0,
! default_order = 3,
! random_number_seed = 9784782334,
! final = "%s.fin",
! parameters = "%s.par",
!&end
!&run_control
! n_steps = 1,
! n_passes = 5000,
!&end
!&momentum_aperture
! output = "%s.mmap",
! x_initial = 0.0,
! y_initial = 0.0,
! delta_negative_limit = -0.1,
! delta_positive_limit = 0.1,
! delta_step_size = 0.005,
! steps_back = 2,
! split_step_divisor = 10,
! splits = 3,
! verbosity = 2,
! s_start = 0,
! s_end = 1,
! include_name_pattern="MA1"
!&end
!&run_setup
! magnets = %s.mag,
! final = "%s.fin",
!&end
!&run_control
! n_steps = 1,
! n_passes = 5000,
!&end
!&momentum_aperture
! x_initial = 0.0,
! y_initial = 0.0,
! steps_back = 2,
! splits = 3,
! verbosity = 2,
! s_start = 0,
! s_end = 1,
!&end
Lingyun
Re: tracking get slower when using multiple watch
Post by michael_borland » 15 Dec 2009, 18:44
Lingyun,
I'm not sure what you are trying to do with this run. Having a DA-search with an initial misalignment and watch points together seems a little confusing. I'd suggest that you just do regular tracking, perhaps with a "dynamic-aperture" beam type generated by bunched_beam.
This could be slow because for each tracked particle it is going to write to the watch file. It involves a lot of disk operations. To make it as fast as possible, be sure FLUSH_INTERVAL=0 and MODE="centroid". Also, if you can work on the local hard disk instead of a disk on a file server, that will help.
Finally, turn off file synchronizaton with this command (should be the first command in the file):
&global_settings
inhibit_fsync = 1
lyyang
Post by lyyang » 15 Dec 2009, 19:37
Sorry, I forgot to comment out the junk pieces.
Thanks Michael:
The inhibit_fsync=1 does help!
lyyang@lyyang-desktop:~/devel$ time elegant track.ele > /dev/null
real 0m2.749s
user 0m2.730s
sys 0m0.010s
real 0m59.292s
user 0m2.990s
sys 0m0.030s
60 seconds vs. 3 seconds for 200 turns tracking. It improved a lot!
Here is the track.ele
&run_setup
magnets = %s.mag,
default_order = 3,
final = "%s.fin",
&run_control
n_steps = 1,
n_indices=0,
n_passes = 200
&twiss_output
statistics=1,
&bunched_beam
&track &end
!&find_aperture
! output = "%s.aper",
! mode = "n-lines",
! xmin = -0.04,
! xmax = 0.04,
! ymin = .0,
! ymax = 0.01,
! nx = 21,
! ny = 11,
! n_splits = 9,
! split_fraction = 0.2,
! n_lines = 5,
! verbosity = 1,
!&end
I didn't use NFS, all operations are on local machine.
Lingyun
Post by michael_borland » 15 Dec 2009, 22:01
Lingyun,
I think this is a result of doing single-particle tracking, which results in very frequent file writing (since the tracking itself is fast). In cases with lots of particles, you'll want to leave file synchronization enabled so that the files update when data is written. Otherwise, you might have to wait a long time to see any data as the program runs.
Probably we should make this automatic...
lyyang
Post by lyyang » 15 Dec 2009, 22:40
I woulkd like this to be automatic, since it is a common job people tracking 200 turns, with 2-3 watching elements. 60sec verses 3 sec is too long for a impatient person like me.
But not so ctirical, since the recipe you gave works very well.
Lingyun
