Sextupole elements
hsayed
Sextupole elements
Post by hsayed » 08 Dec 2009, 12:30
Hi Micheal,
I'm trying to understand how Elegant could be used to correct chromaticity for a ring.
I would like to know how the following Elegant elements would affect chromaticity of a ring, and how differently they would if they all do.
SEXT with zero length
KSEXT with zero length
MULT with zero length ( in the manual it is mentioned that it can not be used for chromaticity. I wonder why?)
SEXT with none-zero length
KSEXT with none-zero length
MULT with none-zero length ( in the manual it is mentioned that it can not be used for chromaticity. I wonder why?)
Thanks
Hisham
Re: Sextupole elements
Post by michael_borland » 08 Dec 2009, 12:39
Hisham,
In order to affect the chromaticity, the SEXT or KSEXT element must have non-zero length. If you need a zero length element, set L=1e-12 or some other very small number. The K2 value is then K2L/L.
If you are planning to do tracking, you should use KSEXT, since SEXT is not symplectic.
MULT elements do not affect the chromaticity only because I haven't coded it. It is on my list of things to do.
hsayed
Post by hsayed » 08 Dec 2009, 14:53
Thanks Michael
How about KQUSE ? does the sextupole filed (K2) affect Elegant chromaticity calculations ?
Post by michael_borland » 08 Dec 2009, 15:26
Hisham,
Yes, the KQUSE element will affect chromaticity computations. Both the quadrupole and sextupole components contribute.
