I tried running the provided file with Pelegant, but now I have encountered an issue. I attempted to use the &sdds_beam command in injection2.ele to read the particle coordinates, but it does not seem to execute correctly. However, the program runs successfully in elegant.
The error message is:
Opening file "beam injection.sdds'
MPI File open failed: other I/o error , error stack:
ADIO RESOLVEFILETYPE FNCALL(78): 0ther I/O error Input/output error
Sincerely,
Ze Yu
Pelegant &sdds_beam issue
- pelegant.zip
- (235.02 KiB) Downloaded 1723 times
Re: Pelegant &sdds_beam issue
I tried this and it ran without any issues on Pelegant. Is there another filesystem you can try?
Which operating system are you using?
