I am using Elegant for longitudinal jitter simulations. The &error_element command is used to add RF phase and cavity voltage errors. I have 1001 injection beam files (inj_0001.sdds to inj_1001.sdds) from the injector's simulation results. I want to simulate injection beam errors by randomly selecting an injection beam file in each step of the calculation. Assume n_steps=101 in run_control, how to randomly select one injection beam file from 1001 injection beam files at each step of the computation? Can input_list &sdds_beam in work? If it works, how to proceed?
Many thanks for any suggestion,
Zhenbiao
How to randomly select one injection beam file from 1001 injection beam files
Re: How to randomly select one injection beam file from 1001 injection beam files
Zhenbiao,
I would combine the input beam files and randomize their order, as follows
This assigns a random number to each page of the combined file, then sorts by that random number.
In elegant, you then use
sddscombine inj_????.sdds -pipe=out \
| sddsprocess -pipe -define=parameter,sortOrder,rnd \
| sddssort -pipe=in randomizedBeams.sdds -parameter=sortOrder
&sdds_beam
input = randomizedBeams.sdds,
track_pages_separately = 1
Many thanks for your quick reply. It works well.
Zhenbiao
Zhenbiao
