Colum munipulate with sdds2stream/sddsprintout
weijie
Post by weijie » 05 Nov 2024, 01:40
Hi Micheal:
I tried to use sdds2stream/sddsprintout to get the data of a branch of watch files named 'run-*.w1'. I want to know how I can get the selected column Sdelta, for example, into one file. Should I use sddscombine or another command? Thank you for your help.
Re: Colum munipulate with sdds2stream/sddsprintout
Post by michael_borland » 12 Nov 2024, 17:09
Assuming your SDDS file is data.sdds, you could use
sdds2stream -column=Sdelta data.sdds > data.txt
to put Sdelta only into a text file.
There's also sdds2spreadsheet, which will make an EXCEL file or other spreadsheet-friendly file.
If you are reading the data into MATLAB or python, we have extensions for doing that directly. See the software distribution page.
weijie
Post by weijie » 13 Nov 2024, 06:56
Cheers!
