ramping with sextupoles
Samira.kasaei
Post by Samira.kasaei » 16 Oct 2024, 06:10
I am using ramping example for my lattice. I wanna to consider the effect of sextupoles to correct the chromaticity. Without sextupoles the particles dont lose while with sextupoles, 70% of the particles lost. I used KSEXT for sextuploes. Could you please take a look at my files?
Many thanks in advance
samira
ramp.tar.gz
(393.5 KiB) Downloaded 5620 times
Re: ramping with sextupoles
Post by michael_borland » 12 Nov 2024, 18:03
Samira,
You are using default_order=1 on &run_setup, which means all matrix computations are done to first order. Hence, the chromaticity appears to be zero, but then you track with KQUAD and KSEXT elements, which have momentum dependence to all orders. You can use a matrix-based dipole magnet with ORDER=1 if you know that this is a good approximation. You can then leave default_order=2 so that matrix computations for quadrupoles and sextupoles capture the chromatic effects.
Also, your KQUAD and KSEXT elements don't have values for N_SLICES, which means it defaults to 1. That's probably not enough. Try N_SLICES=5 and INTEGRATION_ORDER=6 to get a better model.
See the attachment for my changes to your files.
ramp2.tar.gz
(1.6 KiB) Downloaded 5069 times
Samira.kasaei
Post by Samira.kasaei » 17 Nov 2024, 02:57
Many thanks for your reply. It works now. :)
If I wanted to take in to account the effect of eddy current during energy ramping, Is Elegant able to calculate the effect? If yes, how and If you can refer me to an example it is great.
Many thanks in advance,
Samira
Post by michael_borland » 19 Nov 2024, 10:41
Samira,
elegant can't compute the variation of the sextupole due to eddy currents. It depends on many details, such as the vacuum chamber shape and the construction of the magnet. Google is the best place to start.
Samira.kasaei
Post by Samira.kasaei » 21 Nov 2024, 02:28
May I ask you about order in definition of dipole? If I use order =1 for dipole with and without sextupole I don't lose particles. In which case are we using order =2?
Samira
Post by michael_borland » 21 Nov 2024, 10:01
Samira,
The reason you can get away with turning off the sextupoles is that the energy spread and uncorrected linear chromaticities are fairly small and there is no significant nonlinear chromaticity. Hence, the particles tunes don't overlap any dangerous resonances, so nothing is lost.
Samira.kasaei
Post by Samira.kasaei » 13 Feb 2025, 05:17
Many thanks for your reply. I calculated the ramp for 1% energy spread. Without sextupoles I lost 23.4% of particles.Then I applied chromaticity correction to zero and I repeated the calculation. However I lost the same particles again. I was wondering if you can take a look to my files.
Samira
ramp-withsext.tar.gz
(36.82 KiB) Downloaded 5212 times
Post by michael_borland » 24 Feb 2025, 15:26
Samira,
I modified your file to ensure that the chromaticity correction converges. Convergence is slow with three families.
I did tracking and didn't see losses up to 20,000 turns. If you still see losses, I suggest looking at the data turn-by-turn to ensure that the beam is inside the rf bucket. I used an rf voltage pedestal of 0.5 MV.
-Michael
BYBL0.ele
(834 Bytes) Downloaded 4825 times
Samira.kasaei
Post by Samira.kasaei » 18 May 2025, 04:41
Many thanks for reply. I changed my lattice. By Ramping at natural chromaticity, 165 particles lost.
After setting K2 parameters in dipole and in local sextupoles to reach +4 chromaticity, again I repeated ramping but in this case all of the particles are lost. I tried with zero and +1 chromaticities and I got the same results. I was wondering what is wrong!
Here are my files if you can take a look. Many thanks in advance for your support.
Samira
RAMP-1Hz.tar.gz
(36.83 KiB) Downloaded 5136 times
Samira.kasaei
Post by Samira.kasaei » 27 Aug 2025, 06:42
I compared two cases of 1 Hz and 3 Hz for booster ramping.
In case of 1 Hz horizontal emittance and energy spread approach to equilibrium values i.e., at top energy 2.5 GeV while at 3 Hz they are lower than this.
Do you have any comment on this?
Many thanks in advance and Best regards,
Samira
ramp-3hZ.tar.gz
(19.53 KiB) Downloaded 4583 times
