This is Chao. Recently, I am trying to do some study on space-charge effect with elegant.
My question is simple: Can the space-charge effect be simulated with ILMATRIX (one-turn map) by elegant?
I tried this method, however, it seems like the results given out are not as I expected.
Looking forward to your reply and many thanks.
Yours Chao
space charge simulation
Re: space charge simulation
Chao,
I wouldn't expect space-charge simulation to work well with ILMATRIX. The space-charge kicks depend on the beam size, which varies with position in the ring. Also, the kicks from various locations will add or subtract depending on the phase advance.
If you have a large periodic ring, you might get acceptable results by using an ILMATRIX element for each cell. However, the reliability needs to be assessed using element-by-element tracking for these simulations.
