IBS and bunch lengthening due to impedance
Skamarokha
Post by Skamarokha » 22 Mar 2024, 03:02
Hello
I've been trying to setup ibsEmittance and haissinski codes to find beam parameters with consideration of combined effects of IBS and impedance. I see that it has been done before, but I need some advice.
In paper it's said that ibsEmittance code is used to abtain energy spread to use it in Haissinski solver. The latter solves for the bunch length using the wakefield. Iterating between the two codes converges to the solution.
1. I begin iteration with ibsEmittance.
ibsEmittance $twi_file $ibs_file -charge=$charge -emitInput=$ex0 -deltaInput=$sigma_e -coupling=$ratio -length=$sigma_s -noWarning
2. I put new energy spread in twi file for Haissinski solver to use
sddsprocess $twi_file_new -redefine=parameter,Sdelta0,$sigma_e -noWarnings
3. Run solver to find new beam length. twi file has energy spread from IBS and I'm assigning length from ibs solver.
haissinski $twi_file_new $pwd_file -model=Zn=$Zn,R=$R -bunchCurrent=$I -outputLastStepOnly \
 -length=$sigma_t -integrationParameters=deltaTime=$deltaTime,points=4000,iterations=1000,fraction=0.01,tolerance=1e-4
For the next iteration I put in ibsEmittance new total emittance, energy spread and length from previous iteration step. But there is no convergence.
Will it be correct to put RF parameters in haissinski code instead of length with ibs?
What am I missing?
Respectfully,
Mikhail A. Skamarokha.
Re: IBS and bunch lengthening due to impedance
Post by michael_borland » 29 Mar 2024, 16:34
Mikhail,
Please see the attached example. It converges in four iterations.
ibsHaissinskiIteration.zip
(25.33 KiB) Downloaded 2237 times
Skamarokha
Post by Skamarokha » 31 Mar 2024, 22:15
Thank you!
Respectfully,
