A bug in &save_lattice?
yhidaka
Post by yhidaka » 13 Feb 2024, 14:12
If I run the attached ELE file, which changes the values of `N_KICKS` for KQUAD, KSEXT and UKICKMAP elements via `&alter_elements`, then the newly created LTE file `after_alter.lte` (also attached) no longer contains `SYSTEMATIC_MULTIPOLES` for KQUAD & KSEXT.
Could this be related to one of the bugs listed in the ELEGANT manual section 13.33.2?
By the way, UKICKMAP does preserve the string property `INPUT_FILE`.
after_alter.lte
(597 Bytes) Downloaded 2501 times
before_alter.lte
(708 Bytes) Downloaded 2600 times
alter.ele
(498 Bytes) Downloaded 2570 times
Re: A bug in &save_lattice?
Post by michael_borland » 15 Feb 2024, 17:38
The problem is a typo in the definition of the quadrupoles. You have a spurious quotation mark at the end of the lines containing FSE values. This confuses the parser and it ignores the rest of the element definition.
yhidaka
Post by yhidaka » 16 Feb 2024, 09:32
Oh, that was a dumb mistake on my part. The original LTE file is auto-generated by a script in a series of manipulations, and the quote characters appear to be somehow inserted along the way. I'll investigate my code. Thank you very much!
