issue tracking with PELEGANT
After installing PELEGANT on a new cluster I am unable to track particles while the same ele file works fine in ELEGANT. Specifically, PELEGANT seems to do everything fine (e.g. fitting quadrupole magnets) but then does not track the distribution. A simplified example that reproduces the issue is attached along with the outputs from PELEGANT and ELEGANT. You will see that the output is essentially the same except for the "tracking xxx particles" (ELEGANT says 10000 while PELEGANT says 0). I suspect this is a silly mistake on my side. -- Philippe.
Re: issue tracking with PELEGANT
Philippe,
That is very weird. I don't see a problem with either the serial or the parallel version. I tried it on my linux workstation and Improv, with the latest source and version 2023.4.
Are you using Improv? If so, check that you have the right modules loaded:
Also, you can try ~borland/improv/beta/Pelegant and Pelegant_2023.4 (last release).
$ module list
Currently Loaded Modules:
1) .binutils/2.41 (H) 3) tcltk/8.6.13 5) aocc/4.1.0 7) amdfftw/4.1-openmpi-5.0.1-aocc-4.1.0
2) aocl/4.1.0-gcc-13.1.0 4) subversion/1.14.2 6) openmpi/5.0.1-aocc-4.1.0
This gets weirder... I did try to run your exec of pelegant and elegant (on IMPROV) on my .ele file have the same observations: Pelegant does not track while elegant does. The same problem occurs on our new linux computer at NIU. I suspect something is wrong with my ele or lte file, but I cannot just figure it out...
On improv you can see the output and file run in the scratch /lcrc/globalscratch/philippe_testPelegant the stdout have the .output extension.
Thank you! -- Philippe.
and my loaded module and running commands are:
1) .binutils/2.41 (H) 2) aocc/4.1.0 3) openmpi/5.0.1-aocc-4.1.0 4) amdfftw/4.1-openmpi-5.0.1-aocc-4.1.0 5) a
~borland/improv/beta/Pelegant_2023.4 tracktest.ele > pElegantMichael.output
~borland/improv/beta/elegant tracktest.ele > ElegantMichael.output
Philippe,
This command
looks wrong. Are you using mpiexec to invoke Pelegant? E.g., to run with 8 cores you'd use
It shouldn't be possible to run it any other way, but it is behaving as if it is using only 1 core, since particles are generated and tracked only on the slave cores.
Some other suggestions:
* Check your ELEGANT_CONFIGURATION environment variable, if defined. Anything odd about the file it names?
* Try setting bunch=%s.bun in &bunched_beam. Is a file created? If so, does it look odd?
* Try using &sdds_beam instead of &bunched_beam
This command
mpiexec -np 8 Pelegant ...
Thank you. I checked and the .bun file was not be written. I later realize than pelegant has to be run with a np>1 -- for testing purpose in interactive mode I was using mpiexec -np 1 . Changing to -np 4 worked, i.e. particle got tracked. The other codes I used are usually OK with -np 1 so this potential issue did not cross my mind... Anyway as expected it was a user silly mistake. -- Philippe.
Philippe,
The reason that happens in Pelegant is that the master processor is "non-working." It handles coordination among the slave processors, but (usually), doesn't do anything related to particle generation or tracking.
I'll add a check to the code for this problem.
