How does Elegant use input file for FTRFMODE?
WEI-HOU
Post by WEI-HOU » 25 Oct 2023, 18:23
Hello Michael,
How does Elegant use Shunt Impedance, frequency and Q-factor to calculate the voltage and phasor?
Here's how I prepare the data.
I have a spreadsheet of data containing kick factor, frequency and Q-factor.
Screenshot from 2023-10-09 10-36-11.png (5.79 KiB) Viewed 90192 times
I calculate Shunt Impedance based on formula above, and then save Shunt Impedance, frequency and Q-factor into a SDDS data using csv2sdds.
Is this the right way to prepare input file for FTRFMODE?
I have also sent you my Elegant files through email separately.
Thank you.
Re: How does Elegant use input file for FTRFMODE?
Post by michael_borland » 26 Oct 2023, 10:36
Wei-hou,
Yes, that sounds right. We usually get the data from an eigenmode solver that gives the quantities needed directly.
WEI-HOU
Post by WEI-HOU » 26 Oct 2023, 11:30
Hello Michael,
Thanks for the confirmation!
