Access to tracking_based_matrices
Nagaoka
Post by Nagaoka » 23 Oct 2023, 06:23
I would like to know if there is a way to write out and have access to tracking_based_matrices obtained such as on a BGGEXP element.
Thanking you in advance for your kind instruction,
Ryutaro Nagaoka
Re: Access to tracking_based_matrices
Post by michael_borland » 25 Oct 2023, 12:23
Ryutaro,
You can get the matrices from the matrix_output command. It provides the option for a text file or an SDDS file.
Nagaoka
Post by Nagaoka » 27 Oct 2023, 14:00
Hello Michael,
I thank you very much for your helpful instruction. I just tried using this option and I do get matrices for each element in the beamline as well as concatenated matrices. I suppose that the matrices for the BGGEXP elements are obtained from many particles tracking.
The convention for the matrix elements C1, ..., C6 and Rij (i,j=1,...,6), as well as the coordinate system that goes together with the former, can it be found somewhere?
Thanking you again Michael for your kind help,
Ryutaro
