When I set the "open_side" of MAXAMP, I need to specify both X_MAX and Y_MAX, to make the open_side setting take effect. If I only specify one of X_MAX & Y_MAX, it appears "open_side" is ignored. I guess this is somehow misleading. Please see the attached example.
Zhe
Open side in MAXAMP
Open side in MAXAMP
- test_open_side.tar.gz
- (852 Bytes) Downloaded 2409 times
Re: Open side in MAXAMP
Zhe,
Thanks for reporting the bug. It will be fixed in the next release.
A workaround is to set X_MAX=10 (or some other large value).
