Upgrading SDDS version June 4 2009
varese
Post by varese » 07 Sep 2009, 09:21
I tried to upgrade to Elegant22 and SDDS Version June 4, 2009 on my MAC OS 10.5.8
but this is what I obtain trying to use SDDSplot :
"dyld: Library not loaded: /usr/X11/lib/libpng.3.dylib
Referenced from: /Users/cristina/oag/apps/bin/darwin-x86/sddsplot
Reason: Incompatible library version: sddsplot requires version 39.0.0 or later, but libpng.3.dylib provides version 3.0.0"
and this is what fink says:
Information about 4399 packages read in 1 seconds.
i libpng-shlibs 1.0.12-7 PNG image format handling library (old version)
i libpng3 1:1.2.35-2 PNG image format handling library
i libpng3-shlibs 1:1.2.35-2 Shared libraries for libpng3 package
i system-pkgconfig-libpng 1.2.39-1 [virtual pkgconfig package representing libpng]
i system-pkgconfig-libpng12 1.2.39-1 [virtual pkgconfig package representing libpng12]
I installed the version 39 downloading from the libpng.org the darwin-x86 version and probably something is not in the right place...
or I don't know, can you help me?
Thanks a lot
Cristina
Re: Upgrading SDDS version June 4 2009
Post by soliday » 09 Sep 2009, 09:39
Can you run:
otool -L sddsplot
For me this returns:
/usr/X11/lib/libpng.3.dylib (compatibility version 39.0.0, current version 39.0.0)
My system has both /usr/X11/lib/libpng.3.dylib (Xcode version) and /sw/lib/libpng.3.dylib (Fink version). Here is what I get when I run otool -L on both of them:
darwin-x86>otool -L /sw/lib/libpng.3.dylib
/sw/lib/libpng.3.dylib:
/sw/lib/libpng.3.dylib (compatibility version 39.0.0, current version 39.0.0)
darwin-x86>otool -L /usr/X11/lib/libpng.3.dylib
/usr/X11/lib/libpng.3.dylib:
My guess is that it that you might have an older version of Xcode which is getting used instead of the Fink library.
